- Jul 11, 2004
- 990
- 1
- 76
Hi.  When it comes to audio cards my experience is limited.  Since I utilize an audio card for mostly gaming I don't need the best.
However, my son is musically inclined and has been getting into using musical score software. He has a semi-decent keyboard with Midi In/Out jacks. He would like to be able to connect to the PC I built for a second family PC and record his music.
The problem is the current sound card is a Sound Blaster Audigy SE 5.1/7.1. It does very fine for what I built this sytem for but there is no way to connect via midi.
So, any suggestions for a decent card? Again, I don't need the best but something he can start out with and is stable. I couldn't even tell you a budget because I haven't a clue, but let's say no more than $100.
Here are the system specs of the PC he will be using:
EPoX 9NPA+Ultra (socket 939)
Athlon 64 3200+ single core
2 gigs of PC 3200 RAM
250 gig SATA HD 7200rpm
Windows XP w/SP3
Thanks.
Windows XP w/SP3
Thanks.
 Facebook
Facebook Twitter
Twitter
