Need suggestions for a case fan.
zmzhang
I need a new case fan. It needs to be from 8mm-10mm. What is the best fan to get for the cheepest price (~$10)? And which stores offer it?
well, i don't care about the thickness of the fan, as long as it moves alot of air. where can i find the Sunon's ultra-mini's?
thanks
8mm-10mm???
or 80mm-100mm???
Are you looking for ultra mini-size fans? --> I never seen this small size fans.
If you looking for regular 80mm, you can get antec or sunon at bestbuy or compusa.
zmzhang --- for 80mm size
Check For Sale/Trade section..
I saw few guys sell panaflo's over there ... I personally think they are best.
If you like to see it before you buy, go to bestbuy or compusa for antec.
They are okay fans but not best. I am not sure about their price.
Ya the for sale forum might be a good place too look, i just went by some Panaflos, H1a's L1a's and H1T (thin series - 15mm) 80mm fans just a min ago in that forum 🙂
Antec's aren't bad either just just and stick with there ball bearing versions, most of em are rebadged sunons.
GiZzO's Fan Site
