Need suggestion on for PC building with following components
rahul3103
PCPartPicker part list
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive
Video Card: Gigabyte - GeForce GTX 1070 Ti 8 GB Video Card
Case: NZXT - H500 (Black) ATX Mid Tower Case
Power Supply: EVGA - 650 W 80+ Gold Certified Semi-Modular ATX Power Supply
Should I purchase?
G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory
G.Skill - Flare X 16 GB (2 x 8 GB) DDR4-2400 Memory
Need help with the selection of Memory Module(RAM), Keyboard, Mouse and Monitor.
Please help.
dlerious
2,034
851
The Trident Z (non RGB) are cheaper than equivalent Flare X (3200 cas14). At cas16 the Sniper X and Ripjaws V are cheaper. I haven't noticed any difference between the Flare X and Trident Z kits I'm using. I bought the Flare X because of Gskill guaranteeing Ryzen compatibility back when 1800X was released. There's enough users now, that I'd feel comfortable with either.
Keyboard and mouse are pretty subjective - I use Logitech G502 and Ducky keyboard. Need more info on what you'll be doing with monitor. What size, resolution, ultrwide/flat/curved, refresh rate. If you play fast paced games a high-res 1080p panel may be best. If you do video a 1440p or 4k panel may suit you better.
Budget will help narrow down choices as well. Looking at your specs, I'd guess a $2000 4k HDR panel is out.
Flayed
431
102
86
Looks good although you can get an Intel 660p for the same price as the Crucial drive.
