Hello,
I'm in the process of overclocking my VisionTek Xtacy 9500 Pro. I am using RadflasPLUS utility to flash my BIOS. I backed up my original BIOS on floppy and now I'm trying to detemine what BIN file I should flash it with?
The memory I have is the Infineon 3.0. According to rage3d.com, I can choose 1 of 2 BIOSES to flash with. In the RadflashPLUS utility that I downloaded, there is a subfolder called BIOS'z. In the BIOS'z folder there are the BIN files. Now I have a problem which BIN file to flash with. Should it be the---
9500_30 or Original_30 BIN file?
I can't find any info. on which is the correct BIN file? Has anyone ever O.C.ed a VisionTek Xtacy 9500 Pro card? If not, does anyone have any suggestions which BIN file to use? I have searched VisionTek site(not like there going to publish this info.) and no such luck.
Any info. would be much appreciated.
Thanks
Thanks
