Originally posted by: GimpyFuzznut
I'm going to be doing a similiar build soon with a P180 case. Probably going to go with a Scythe Ninja... from what I read it is the best choice. Little pricey but worth it if you are going to overclock. Probably don't even need to put on an extra 120 fan if you got the right motherboard.... me, I'll probably through one of those quiet Panaflo or Nexus fans on it. Might add one in front of the hard drives as well.
In a nutshell.....Originally posted by: cw42
big typhoon
or
scythe ninja/xp90/xp120/si120 using a low flow panaflo fan, or a yateloon if the heatsink is 120mm.
