- Dec 9, 2001
- 5,710
- 0
- 76
I'm thinking of doing a strut job myself but I need to buy some spring compressor... which ones do you recommend (preferrably cheap)
thanks
thanks
thanks
Originally posted by: JC
Those springs can be a real pain.....if you're set on pulling the struts yourself, I'd say take them to a front-end shop with the new struts, and pay them a few bucks to swap the springs onto the new struts. The only compressors that work worth a damn are kinda pricey, if you're only doing it once
JC <----- former front-end mechanic
I don't recall it being very hard at all.
Note: I suppose its a tougher if you have to compress the springs while they're on the car. I didn't have to. Thanks Honda!![]()
Originally posted by: Tominator
If you buy the struts from Autozone or you favorite chain store, they will loan you the tools at no cost. You just leave a deposit.
Originally posted by: Antisocial-Virge
Don't mess up. A slip can take your head off with those things
