shortylickens
In one of my homework problems it asks to find the probability (area under curve) of some stuff, but it says the data is uniformly distributed, not normally distributed.
And since its only got nine samples, I cant assume its approximately normal either. No point in determining the Z-scores if its not a proper curve, though I could with the data given.
Already emailed the teacher but on a saturday I doubt I'll get a quick response.
Have any of you guys ever assumed a uniformly distributed curve is also a normal curve?
I think I may run the numbers anyway, intercept the teacher before class and if she says I cant assume that, erase it and put No Possible Solution.
The only reason this one is weird is I think she said there might be a problem I cant do and also because its sandwiched between two J-curves with a crapload of samples (way over 30).
