computerbuildin
Im just looking for a pretty fast SSD, not very expensive. I currently have a 500GB WD Caviar blue and I wanted something to load programs alot faster and have a much faster boot time. I've looked into many SSD's but im not sure on how I should make my decision. Mainly because it would be a swap from the HDD to the SSD, and I already have used 222 GB of it. I found that the easiest possible way to move stuff was to copy it all, like using norton ghost or any other programs like that. That would be the lazy way too, but doing the whole windows movement thing is just really complicated to me unless there was an easier solution. Because I dont want to mess anything up in the process of doing the transfer. So basically for SSD's im looking for a range of 200 GB-250 GB <- That might be wrong because the windows partition take up about 35 GB, you can tell when you would go to properties on the HDD. Bare its 500 GB but with windows its displayed as 465 GB. If im correct there.... So it could be possible that I need even a 300 GB SSD. So I just need some answers to figure out how this transfer would work and what SSD's I should look at.
