FoBoT
i have a section of my basement that is unfinished, bare studs, open ceiling etc.
the furnace and hot water heater are back there, along with storage , and most importantly, my PC's workshop and servers/etc.
the fan noise is starting to get noticeable in the rooms adjacent and the room above.
so i want to put something between the studs/against the back side of the drywall and up in between the floor joists (the ceiling of my "Cave") to dampen the sound
i figure normal fiberglass insulation will be cheapest, but what are my alternatives?
i don't want to spend big $ , but i need to muffle the sound a bit
thanks
thanks
