need some web site help w/ DNS i think
bmacd
10,869
I registered bmacd.net and afterhourscarclub.com. bmacd.net is my reseller's account, and afterhours is a client. I bought the domain names through namecheap and setup bmacd.net as a nameserver.
The sites were both working perfect yesterday afternoon (confirmed by local friends and Rossman), and then yesterday evening, it stopped working. Is it a problem with my DNS/namecheap or with the hosting company?
aim: bmacd95b
-=bmacd=-
Heisenberg
10,621
I can't get either hostname to resolve, so it sounds like a DNS problem. Or it may be RR's crappy DNS.
DeviousTrap
4,841
Just ran a check from my server as well as home. Correct your nameservers are set up correctly but not resolving.
My suggestion: Go into your account at enom and delete the nameservers, then recreate them. This will take 24 hours (they need to propegate again) and you should be all set. Basically something with your nameservers is corrupt. Most likely enom did some update and then dns entries on your domain got messed up.
RossMAN
Grand Nagus
Feb 24, 2000
78,928
389
Login to NameCheap.com again
Modify both your domains
Make sure you are using YOUR DNS name servers
ns1.bmacd.net
ns2.bmacd.net
Also were your name servers setup correctly when you registered them? I should be on AIM in 2 or so hours, we can chat then.
DeviousTrap
4,841
ns1.bmacd.net
ns2.bmacd.net
He should be all set now, just talked to him on AIM.... I was wondering how Ross could confirm a site being down but not offer to help :confused:
