Hey all, not sure where this should be posted, but as it relates to an idea for an invention I have I would appreciate your assistance. Some of this stuff is pretty off the wall. And for the record, I'm not looking to do any peeping, so no comments re: the camera. Also, I did google for this stuff and can't quite find what I need.
Ok, here is what I am looking for:
1. A small (.5"X.5" or smaller) "coring" drill with an attached driving motor. The drill/motor needs to be strong enough to bore through wood 2x4's. I've seen boring drill bits of the size I am talking about, but they are all used in conjunction with a hand held power drill. I need something substantially smaller and powered by a much smaller motor.
2. A wire that is stiffer along its long axis then it's circumferance, and which may be flex via remote or tension means to flex in various directions. I'm thinking something along the lines of the camera/cable that SWAT teams use to peer under doors or around walls, only much longer. Another way of describing it would be something similar to the guidewires used to implant stents or some of the components of an artheroscope, only much stiffer and stronger, and probably longer (sheesh that sounds wrong, but only way I can describe it).
3. A miniature (.5" or smaller) black and white video camera with or without a built in light source (i.e., an LED). If no light source, I'm looking for an LED light source suitable for such a camera.
Thanks in advance.
Thanks in advance.
