Need Some Trillian Help
NakaNaka
6,304
Seems Trillian is playing the user signing on message when a user comes back from Away. I can't seem to find a way to disable it. Any help?
Thanks
P.S. What are some cool hidden features in Trillain. I just downloaded it.
NakaNaka
6,304
You think I haven't been screwing around in there. I just want to know how to disable this one thing. Geez.
PullMyFinger
728
Originally posted by: ffmcobalt right-click the icon that's down next to the clock. Look for properties. Learn for yourself. :)
nik
Wow, "Learn for yourself", that's reaaal helpful, A$$ Munch!
Now to help Naka Naka, my only suggestion would be to mess around with the advanced settings under Preferences, Events. There is a tab labeled "Advanced" which will allow you to change what event triggers which type of response (ie, make a sound, run a program, open a chat window, etc). Hope you find what you're looking for.
PS, on the preferences list, the first selection is Basic Options. Once in Basic Options, there is a check box at the bottom right labeled "Send Anonymous Usage Statistics". Mine was checked by default, you may want to see if your's is checked, I don't really care to provide "anonymous" statistics to anyone.
