Need some tech help
NakaNaka
6,304
Alright this is really strange. The site I work for Intelgamer I used to always connect to really fast. All of a sudden it is going really slow for me and not for anyone else I know. What is it? I have tried restarting, booting under ME that didn't work then going back to XP no difference.
WHat is it?? All the other sites I connect at great speeds (I'm using cable) but not IG and it happened all of a sudden. Everyone else I know is getting good speeds. Please check how fast you connect to it and tell me what could be wrong ... Thanks
-phil
SupaDupaCheez
2,034
NakaNaka: I don't think it's you. I also have a cable connection (a pretty fast one too :)) and it took over 20 seconds to load up. I tried it twice (after deleting my Temp Files) and it wouldn't load up at all. I know this doesn't give you an answer as to 'why' but at least you know you aren't the only one!
SDC
NakaNaka
6,304
Thanks ... Anyone else ... The site admin says he is getting good speed/pings and that there is nothing wrong with the server. I hope they fix it soon. It wouldn't be bad but I work here.
hungrypete
3,001
isn't that site a CS 1.3 mirror? That would explain the sluggishness (very slow for me too).
SupaDupaCheez
2,034
I just tried to ping the site and this is the results:
C:\WINDOWS>ping intelgamer.com
Pinging intelgamer.com [12.96.164.104] with 32 bytes of data:
Reply from 12.96.164.104: bytes=32 time=66ms TTL=115
Reply from 12.96.164.104: bytes=32 time=65ms TTL=115
Request timed out.
Reply from 12.96.164.104: bytes=32 time=64ms TTL=115
Ping statistics for 12.96.164.104:
Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),
Approximate round trip times in milli-seconds:
Minimum = 64ms, Maximum = 66ms, Average = 48ms
Looks like something might be wrong on his end. I'm not an expert by any means but seems like he has some problems.
SDC
NakaNaka
6,304
hungrypete we are mirroring linux files now and at 2pm est we will have the cs retail and cs mod files for everyone to download so we will be hit hard .. but that doesn't explain why its slow right now ....
TonTo
Banned
Jul 9, 2001
368
dude, most internet traffic is slow today....
freakin nimda virus... it's probing ALOT of sites.....
where i work(wireless ISP in central MN) we've noticed about 20 times as much broadcast traffic as we normaly do....
