need some snow tire help from you guys
toph99
5,505
i have 215/70r15's on my crown vic(15x6 or 6.5" rim) and i want to fit some snow tires on it. The kind i want don't come in my stock size, but i'm not sure how much i can vary width/aspect ratio on a 15x6 rim, and i'm horrible at stuff like this. i can possibly get some steel 16" rims if need be. these are the available sizes
any input or help is appreciated :)
notfred
38,241
4
the P205/70R15 95Q will fit alright, it'll just make your speedo and odometer read 2% higher than accurate. Might look kinda skinny too, but I've head skinny is good in snow... I dunno, I live in California.
toph99
5,505
i don't want to adjust my speedo...(wow that sounds bad... lol) is that all the percent difference it'll makr with a 205? i can't remember if aspect ratio is of tread width or rim diameter :eek: and yeah, skinny is good in snow, cuts through the slush and stuff
notfred
38,241
4
ratio is based on width, not diameter. 2% isn't too bad... if you drive 5,000 miles on the tires, it'll show up as 5100 miles on the odometer. If you're going 50mph, your speedo will read 51mph.
olds
50,113
775
I live in CA too and I grew up driving in snow.
Iron Woode
31,255
12,777
I take it you have an older Crown Vic. I have an 87. Same size rims too. I use Arctic Alpin 225 70 15. Works great.
Edit: Stock tires are listed on a sticker on the passenger side rear door near the door catch (above the tire). A 225 70 15 is police issue and won't affect your speedometer.
toph99
5,505
mine's a 93. they use the same wheels from 87 to 99 or 2000 IIRC. i was thinking about arctic alpins but they're more for packed snow, most of the stuff i drive in is THICK slush and snow. those ice tracks are sort of a cross between arctic alpins and deep snow tires
Iron Woode
31,255
12,777
Trust me, those Alpins work great in slush and rain too.
A good tire from a good company can't be beat.
Where in Ontario are you?
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Personally I like Bridgestone Blizzaks, they do a great job on my sister's 1982 BMW 320i.
ZV
yobarman
11,642
i'm looking for snow tires for my 1990 Chevy Lumina V6, i was wondering do i only need the tires on the front wheels? would it fishtail or anything if i keep the olds ones on the back? i'm gonna be up in rochester ny...and it's bloody wet up there :(
vi edit
62,484
8,345
Most stores won't even let you buy them in twos. I would most certainly put them on all four wheels.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
You're kidding right? We had no trouble at all getting only two snow tires for my sister's RWD 320i.
ZV
EDIT: Re-thinking things, only two tires would work better for RWD than for FWD, so what I've said doesn't really compare well. Still, I think that most stores will be OK selling in pairs.
vi edit
62,484
8,345
Everyplace that I've looked (tirerack, sears, and another local shop) only sell snow tires in fours. All cars that I checked into them for were FWD, so I don't know if that has any bearing or not.
Tom
If your car's speedometer is calculated for 215s then running larger or smaller tires will affect the speedo to some extent. The 215 number is the height of the tire and the only number you need to worry about as far as the speedo is concerned.
The aspect ratio is just the ratio of the width of the tire to the height of the tire. According to this Yokohama tire guide you should be ok with 215/70s or 215/60s on 6 inch rims. It's probably a reasonable assumption that other brands would have similar requirements.
guide
Also I wouldn't drive around too much with these soft snow tires on your car unless it's snowy. They will probably wear pretty quick.
