- Jul 14, 2005
- 29,307
- 106
- 106
I have used this tutorial http://itp.nyu.edu/physcomp/Labs/DCMotorControl
But it's lacking two things
1) Needs a switch so i can have it turn the ASAP and not have to wait for the Arduino to boot
2) I need to figure out how after the switch^ is turned on the motors only run for X amount of time
This is all for a small physics project, the car needs to travel 5m
Thanks for all your help
Alfa
int switchPin = 2; // switch input
int motor1Pin = 3; // H-bridge leg 1 (pin 2, 1A)
int motor2Pin = 4; // H-bridge leg 2 (pin 7, 2A)
int enablePin = 9; // H-bridge enable pin
int ledPin = 13; // LED
void setup() {
// set the switch as an input:
pinMode(switchPin, INPUT);
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin, OUTPUT);
pinMode(ledPin, OUTPUT);
// set enablePin high so that motor can turn on:
digitalWrite(enablePin, HIGH);
// blink the LED 3 times. This should happen only once.
// if you see the LED blink three times, it means that the module
// reset itself,. probably because the motor caused a brownout
// or a short.
blink(ledPin, 3, 100);
void loop() {
// if the switch is high, motor will turn on one direction:
if (digitalRead(switchPin) == HIGH) {
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2Pin, HIGH); // set leg 2 of the H-bridge high
// if the switch is low, motor will turn in the other direction:
else {
digitalWrite(motor1Pin, HIGH); // set leg 1 of the H-bridge high
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge low
blinks an LED
void blink(int whatPin, int howManyTimes, int milliSecs) {
int i = 0;
for ( i = 0; i < howManyTimes; i++) {
digitalWrite(whatPin, HIGH);
delay(milliSecs/2);
digitalWrite(whatPin, LOW);
delay(milliSecs/2);
Alfa
