Need some real tech help!!
DigitalCancer
3,726
Ok...heres my setup...
FoxConn 975X7AB (newest bios)
E6400 Core2
Seagate SATA2 (ST3300620AS)
x2 1GB OCz PC2-6400
eVGA 7600GT KO
WinXP Pro SP2 (latest updates)
Ok, so...my problem is kinda random, whenever i install something (usually applications) my computer will boot just fine until the welcome screen, then it loads stuff in the background, but the welcome screen stays, prolly about an extra 20 seconds. USUALLY i can do a system restore, and it'll be fine again. This time i decided to see if i could fix it..again...i used Recovery Console, and ran CHKDSK /R and it actually did fix a few problems, well..now i can't even do system restore, no matter where i choose, it comes back and says that system restore could not be performed.
I am pretty sure that my main prob (welcome screen) is a corrupted registry issue but i'm not really sure. Below this post i will display my ntbtlog that i made to see if maybe that will help anyone to help me. I am out of ideas.
::RECAP::
-Welcome screen hangs after installation of software (but not always, also not specific proggies)
-done chkdsk, fixed errors on drive
-defragged drive
-formatted (in the past)
-System restore now doesn't work, after running chkdsk.
DigitalCancer
3,726
HERES MY BOOTLOG:
Service Pack 2 1 11 2007 14:52:44.375
Loaded driver \WINDOWS\system32\ntkrnlpa.exe
Loaded driver \WINDOWS\system32\hal.dll
Loaded driver \WINDOWS\system32\KDCOM.DLL
Loaded driver \WINDOWS\system32\BOOTVID.dll
Loaded driver sptd.sys
Loaded driver \WINDOWS\System32\Drivers\WMILIB.SYS
Loaded driver \WINDOWS\System32\Drivers\SCSIPORT.SYS
Loaded driver Vax347b.sys
Loaded driver ACPI.sys
Loaded driver isapnp.sys
Loaded driver ohci1394.sys
Loaded driver \WINDOWS\system32\DRIVERS\1394BUS.SYS
Loaded driver pci.sys
Loaded driver pciide.sys
Loaded driver \WINDOWS\system32\DRIVERS\PCIIDEX.SYS
Loaded driver MountMgr.sys
Loaded driver ftdisk.sys
Loaded driver dmload.sys
Loaded driver dmio.sys
Loaded driver PartMgr.sys
Loaded driver sfsync02.sys
Loaded driver VolSnap.sys
Loaded driver atapi.sys
Loaded driver Vax347s.sys
Loaded driver disk.sys
Loaded driver \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
Loaded driver fltMgr.sys
Loaded driver sr.sys
Loaded driver PxHelp20.sys
Loaded driver KSecDD.sys
Loaded driver Ntfs.sys
Loaded driver NDIS.sys
Loaded driver sfhlp02.sys
Loaded driver sfdrv01.sys
Loaded driver Mup.sys
Loaded driver \SystemRoot\system32\DRIVERS\intelppm.sys
Loaded driver \SystemRoot\system32\DRIVERS\nv4_mini.sys
Loaded driver \SystemRoot\system32\DRIVERS\HDAudBus.sys
Loaded driver \SystemRoot\system32\DRIVERS\yk51x86.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbuhci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\nic1394.sys
Loaded driver \SystemRoot\system32\DRIVERS\fdc.sys
Loaded driver \SystemRoot\system32\DRIVERS\serial.sys
Loaded driver \SystemRoot\system32\DRIVERS\serenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\irsir.sys
Loaded driver \SystemRoot\system32\DRIVERS\irenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\parport.sys
Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\imapi.sys
Loaded driver \SystemRoot\system32\drivers\pfc.sys
Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\system32\DRIVERS\redbook.sys
Loaded driver \SystemRoot\System32\Drivers\GEARAspiWDM.sys
Loaded driver \SystemRoot\System32\Drivers\ahdy4rq9.SYS
Loaded driver \SystemRoot\system32\DRIVERS\audstub.sys
Loaded driver \SystemRoot\system32\DRIVERS\rasirda.sys
Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys
Loaded driver \SystemRoot\system32\DRIVERS\msgpc.sys
Loaded driver \SystemRoot\system32\DRIVERS\psched.sys
Loaded driver \SystemRoot\system32\DRIVERS\ptilink.sys
Loaded driver \SystemRoot\system32\DRIVERS\raspti.sys
Loaded driver \SystemRoot\System32\Drivers\pcouffin.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdpdr.sys
Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\system32\DRIVERS\update.sys
Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
Loaded driver \SystemRoot\system32\drivers\RtkHDAud.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys
Did not load driver \SystemRoot\System32\Drivers\lbrtfdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Flpydisk.SYS
Did not load driver \SystemRoot\System32\Drivers\Sfloppy.SYS
Did not load driver \SystemRoot\System32\Drivers\i2omgmt.SYS
Did not load driver \SystemRoot\System32\Drivers\Changer.SYS
Did not load driver \SystemRoot\System32\Drivers\Cdaudio.SYS
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Did not load driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\System32\drivers\vga.sys
Loaded driver \SystemRoot\System32\Drivers\mnmdd.SYS
Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\rasacd.sys
Loaded driver \SystemRoot\system32\DRIVERS\ipsec.sys
Loaded driver \SystemRoot\system32\DRIVERS\tcpip.sys
Loaded driver \SystemRoot\system32\DRIVERS\ipnat.sys
Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys
Loaded driver \SystemRoot\system32\DRIVERS\netbt.sys
Loaded driver \SystemRoot\System32\drivers\afd.sys
Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys
Did not load driver \SystemRoot\System32\Drivers\PCIDump.SYS
Loaded driver \SystemRoot\system32\DRIVERS\arp1394.sys
Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\System32\Drivers\Fips.SYS
Loaded driver \SystemRoot\System32\Drivers\Cdfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Loaded driver \SystemRoot\System32\Drivers\Razerlow.sys
Loaded driver \SystemRoot\system32\DRIVERS\hidusb.sys
Loaded driver \SystemRoot\system32\DRIVERS\mouhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\irda.sys
Loaded driver \SystemRoot\system32\DRIVERS\ndisuio.sys
Did not load driver \SystemRoot\system32\DRIVERS\rdbss.sys
Did not load driver \SystemRoot\system32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\system32\drivers\wdmaud.sys
Loaded driver \SystemRoot\system32\drivers\sysaudio.sys
Loaded driver \SystemRoot\system32\drivers\splitter.sys
Loaded driver \SystemRoot\system32\drivers\aec.sys
Loaded driver \SystemRoot\system32\drivers\swmidi.sys
Loaded driver \SystemRoot\system32\drivers\DMusic.sys
Loaded driver \SystemRoot\system32\drivers\kmixer.sys
Loaded driver \SystemRoot\system32\drivers\drmkaud.sys
Loaded driver \SystemRoot\system32\DRIVERS\mrxdav.sys
Loaded driver \SystemRoot\System32\Drivers\ParVdm.SYS
Loaded driver \SystemRoot\System32\drivers\aspi32.sys
Loaded driver \SystemRoot\system32\DRIVERS\atksgt.sys
Loaded driver \SystemRoot\system32\DRIVERS\lirsgt.sys
Loaded driver \SystemRoot\system32\DRIVERS\srv.sys
Loaded driver \SystemRoot\system32\DRIVERS\secdrv.sys
Did not load driver \SystemRoot\system32\DRIVERS\ipnat.sys
Loaded driver \SystemRoot\System32\Drivers\HTTP.sys
DigitalCancer
3,726
someone PLEASE help. I went ahead and done a format. Got all my stuff installed again, forgot to set a restore point (doh!) so now i'm back where i started, lol. Was nice to boot w/o the delay again though, but bliss only lasted a bit. =/
