Need some quick SQL help! left/right/inner joins
robphelan
Hey everyone.. I'm trying to figure out this seemingly simple join over 3 tables. They are related as:
Header
Detail
Other_Detail
Header.key_field = Detail.key_field1
Detail.key_field1 = Other_Detail.key_field1
Detail.key_field2 = Other_Detail.key_field2
The only problem is that Other_Detail may or may not have any data for the key_field combinations.
I need the records returned if there is anything in the Header / Detail tables.
I thought I had it.. but i'm only getting return values if data exists in all 3 tables.
thanks a bunch.
RP
ok.. nevermind.. I cheated.
I created one view as an inner join on Header / Detail and then a second view on View#1 left inner join + Other_Detail.
You just need a left outer join to preserve the data in the header and detail tables when there are no records in the dependent table, i.e.
select a.*, b.*, c.* from
header a
join detail b on a.key_field = b.key_field1
left join other_detail c on b.key_field1 = c.key_field2
