- Jun 4, 2004
- 17,522
- 15,564
- 146
I've finally gotten my house back together after hurricane Ike ripped the roof off of my house and collapsed half the ceilings.
I'm just now getting around to filling out the personal property loss worksheets for the insurance and I need some idea on what the replacement cost is for the speakers I have. (If I don't provide either an actual cost or reasonable replacement cost they'll low ball me)
Normally I would just use the receipts as my wife and I keep all receipts, by month for 7 years but I can't find the ones for the my speakers.
My speakers are:
Sony SA-VE445H HT speaker system
1X Powered Subwoofer:
* Reproduction Frequency Range: 26-200Hz (no dB variation given)
* Continuous RMS Power Output: 135 watts (6 ohms, 20-20,000Hz, 0.8% THD)
5X Satellites:
* Rated Impedance: 8 ohms
* Maximum Input Power: 120 watts
* Sensitivity Level: 84dB (1W, 1m)
* Frequency Range: 120-50,000Hz (no dB variation given)
Any idea on what a similar level replacement set off speakers would cost?
(I believe the system was in the $250 - $300 level)
Any recommendations on what to replace it with? (can be more expensive)
The room they were/are to be mounted in has 18ft ceilings and is pre-wired for 5.1 surround sound with the speakers mounted about half way up. The room itself is roughly 20x20ft.
Thanks for any help.
My speakers are:
5X Satellites:
