need some power mac help
alfa147x
29,307
i whant to make it communicate with my pc amd 64 fx 521gs left of harddisk space 4 gigis of ram connect to a wireless network that on 5 mb cable
i need to be able to acsess files all by ethernet my xbox live will work through that ether net port on the pc now i whant my mac to
i have a power mac g3 beige 128ish mbs of ram like 250mb hardisk space left and dont feel like upgrading
thanks
my g5 is connected to the home network by gigabyte ethernet
notfred
38,241
4
Originally posted by: alfa147x
Originally posted by: cscpianoman
You might want to try a different forum.
Any personal picks ?
Any forum where they spend the next ten years teaching you English. When you come back here, maybe you'll be able to form an intelligible sentence.
gsaldivar
8,691
LOL
QFT :thumbsup:
alfa147x
29,307
sure but no i need to know what programes i need on bith boxes and on neede to be compatible with 10.1
flot
3,197
You need stacker, drivespace, or disk doubler. You'll be fine.
You could also find some files you don't use very often and zip them - then arj the zip - then rar the arj - and then zip the rar. Eventually if you keep going they won't take up much space at all. But you can't do the same one twice in a row - the hard drive companies won't let you do that becuase they'd lose too much money.
JoeKing
SLAP!
that's for trying to be helpful in OT
35,576
Acoustic coupling should work fine, just be sure both boxes have good sound cards.
Wahsapa
3,004
apple menu/ system preferences/sharing... figure it out from there :p
also, please learn english... and uhh... post in the right forum
tami
11,588
<a target=_blank class=ftalternatingbarlinklarge href="http://forums.anandtech.com/categories.aspx?catid=36&flcache=4388052&entercat=y">
thanks
my g5 is connected to the home network by gigabyte ethernet</a>
edit: :D
