Hey all, got a question that i cant find the answer for. i've searched high and low, near and far. nothing.
ok. so when i download the RAW files off my 300D, import them into photoshop I usually assign them to the ProPhoto ICC profile to give better color depth. image always displays just fine in PS CS2, but whenever I try and view the picture ANYWHERE else, you can tell it reverted back to a different ICC profile (colors dont look nearly as vibrant).
I usually do all my work in 16bit, then after I resize the final image i convert down to 8bit and save as a JPEG on the highest quality available.
Anyone know whats going on? I suspect its got something to do with the JPEG format, maybe if I saved it as a TIFF it wouldnt happen anymore? this is damn annoying, because the pictures always look fantastic in PS, but anywhere else they look.. dull.
what could be the culprit?
thanks!
thanks!
