Need some painting help
Status
Not open for further replies.
Pardus
8,197
21
Looking to paint my place soon, need some advice as i have never painted this much area by myself and want to do it right.
1. Going from a dark color to all white, do i need primer?
2. Is there any paint that has primer built in?
3. What brand of paint covers and cleans easily, ex: Olympia, Benjamin Moore, Behr, Shermin Williams and so on.
4. How do you paint over electrical outlets/wall switches/phone jacks. I can remove the plates, but the outlets are painted with a dark color, would like them to be plain white without replacing them.
5. Any good tips to paint baseboards, windows and other areas that are just difficult. Do i need to put down tape all around these areas, would be a lot of tape.
There is a lot of prep work to do as well. Thanks all.
olds
50,125
779
Maybe
Yes. I just used Behr. It's not a fix all.
Don't scrimp on paint. Get their best.
With a roller that's not too wet.
If you're not experienced, blue tape and a sash bush. If it's one coat, I freehand.
Bolded
thedarkwolf
9,034
127
Lowes and Home Depot both have paints with primer built in. I didn't have great results with the Home Depot stuff going from dark to light but that may have been my stupid textured walls. They are just a pita to get good coverage on. I hate taping HATE IT so I just free hand the trim. Get a good quality angled brush and give it a try. Keep a wet rag/sponge handy and wipe off anything you do get on the trim and you won't have any problems.
blackangst1
22,902
2,359
Maybe
Good advice. Of the brands you listed, Sherwin Williams is about the best. Behr would be my next bet. Both make a paint with primer built in. That said, you may need 2 coats.
For outlets, just take off the covers and roll around them.
Use LOTS of blue tape! Dont scrimp on tape either. Get the real stuff.
USE DRAPE SHEETS!
There are also lots of videos on youtube with painting tips i.e. propeer way to cut in, etc.
lxskllr
60,340
10,743
I don't like painted outlets. They get chipped up, and it looks like a half assed hiding job. I prefer "Look at me! I'm an outlet!" than "Don't look over here, I'm trying to hide in a corner". Remove the plates, paint the walls, put the plates back.
Pardus
8,197
21
thanks all, appreciate the advice, the yellow walls are making me insane, has got to go.
lxskllr
60,340
10,743
Wow, that's really bright. I like unusual/unorthodox colors, but that's a bit much :^D
JPS35
890
83
Regarding paint, is this a 1/2 bath you are painting or does it also have a shower/tub? If it is just the 1/2 bath, use a semi gloss latex. It is easy to clean up, easy to touch up, and covers well if you get a good,quality brand. The yellow is lighter than you think, but it certainly would be good to go over it with a primer and see how much the color bleeds through. In any case, use at least two coats of your main color. If it is a full bath, you might want to consider using an oil based paint to prevent steam/water damage. It is tough to clean up, but would be better in this case.
Why paint the outlets? Take the plates off and buy some new switches they are generally cheap and easy to switch out with the old ones.
If your walls have no finish to them, you can tape the trim with a tape tool that makes it fast and easy. Use the wider blue tape (1 1/2 - 2") as it makes it easier to get off when completed. I also generally re-tape between coats so the tape does not become part of the wall or tear the paint.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Yellow is not my favorite color but, if you paint the walls to match the door, I might have to cut my throat just to add some color to the place. WTH is it with people painting everything white? Makes me want to chug a bottle of bleach and finish the job.
Status
