Need some P2 help - Done, thanks
Migroo
4,488
9
Hi Guys,
Sorry to post this, its a really easy thing to do i bet, just not for me...
I've never have to install / remove a PII before and I cant for the life of me figure out how to remove the CPU from its socket...
I'm doing this so I can clean up the HSF.
Thanks
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
16
Push in the tabs at the top of both ends of the cartridge and lift straight up. It needs some very firm force to pull it out of the slot. You may need a bit of help: one person to push the tabs in and the other to pull the cartridge up out of the retainers.
oldfart
10,207
If its a real old one like a PII 233-300, there is a clip on two pins down at the base of the CPU that has to come off.
Migroo
4,488
9
Thanks guys
Yep I should have said - its a P2-350.
I'll have another go once I've finished re-building this server.
Migroo
4,488
9
Thanks guys, I've done it.
You were right about needing some force Andy! :Q
Appreciated guys, thanks.
