I was making some upgrades to my computer and when I finished this is what happened. After turning it on I went into the bios screen to monitor cpu temp and while watching it for about 10 seconds (CPU up to 28C) the screen just frooze. I thought i smelled something funny so i just turned it off. I then checked everything and powered it on again but this time the nothing would post on my monitor, videocard fan and cpu fan were running.
My MB is a ALBATRON KX18D NForce Ultra 400 and CPU is +2600 Athlon XP Mobile and these were the changes I made:
1. Removed heatsink and reapplied Artic Silver grease
2. changed Sparkle 300 PS to a Rosewill 550
3. changed Crucial 512mb PC2700 to a PQI 512mb PC3200 stick
4. changed Maxtor 40 GB to a Maxtor 160 GB Harddrive
5. changed CD burner out with new Lite-on DVD burner
Now after this happened I took everything back apart, I didnt see any burn marks on the MB or CPU, also the CPU had good contact with the HS/Fan from the impression on it. I even retried with all the old parts but nothing. This MB is also suppose to have a termal protection for the CPU to shutdown if it gets to hot. So my question is do you think my MB, CPU or both went bad?
