Need some info on snorkeling gear
Kerouactivist
4,665
I'm headed to Mexico later this weekend and need to get some gear before I leave any suggestions?
Narse
Moderator<br>Computer Help
Moderator
Mar 14, 2000
3,826
Fit and comfort are the most important feature, If you can try to goto a local dive shop. They should help you find something that will work for ya.
ttown
2,412
Do as narse suggests
I bought a us-diver package from Big-5 for $25 (reg $50) without any knowlege and pretty much lucked out with something that fits well. In hindsight I should have tried it on before I bought and should have known how to check the fit -- but I lucked out. The generic package probably would leak for many many people.
As an alternative for your trip, I'd suggest trying out a scuba class which are probably common in mexico -- especially if you're staying at a touristy resort.
I tried an "intro" scuba session that was only in a deep pool -- and it was great. I'd think it would be great X 10000 in the ocean.
(I'm hooked enough on scuba to be looking into an actual padi certification class -- which I expect to take before next summer)
Kerouactivist
4,665
I'm thinking about giving it a try apprently snuba is kinda cool too...
ttown
2,412
I never heard of snuba, so I looked it up....
It looks fun, but not nearly as fun as scuba. I'd spend the extra $$ for the more amazing experience.
