Need some info from rollerbladers
jaylek55
I've been thinking about learning, ya know something to do on a nice day, instead of sitting my already fat ass. Problem is I know nothing about rollerblading. Does anyone know of some good resources? Online would be ideal but any other resources wouldn't hurt either. Help me, help my fat ass get off my couch. 🙂
How is reading about rollerblading on the internet going to get your fat ass off the couch?
Buy rollerblades > skate.
There's not a whole lot of learning to do that doesn't involve actual skating.
Just make sure to cover up as much of your skin as possible and do not skate on public roads or on uneven surfaces.
Parking lots are the best place to learn to skate.
Do not forget wrist guards and i would suggest getting those wrist guards attached to the glove. Chances aer when you fall you'll berak the fall with your hands.. Good idea to protect them
No reading will help you with your balance. Get skates and practice where there are no people and cars to run you over. Stay away from any roads, since you dont want to accidentally roll towards a road coz you cant stop.
Go slow, low and bend at the knees. Never stand up straight and lock your knees. Use your hands to balance initially.
Good luck...break a leg 😉
Yes, get wristguards and kneeguards. You WILL fall when you're first learning, but these help you overcome fear because you know it won't likely hurt when you do.
Also stay away from roads, especially hills. 😀
A tennis court (if there are no strict rules prohibiting this) is a great place to learn. Problem is, since it's warm, they're usually taken by tennis players (damn them). I learned to play hockey by starting out on the tennis courts... never have I looked back. You won't regret it once you're out there.
Bottom line, you just gotta go out there and skate. Push off one leg and learn balance first. It's all something you have to become accustomed to. People can't do backflips simply because they want to... they have to orient & train their mind first by doing the motions... so get out there and buy a pair of $50 - $100 skates and have at it. Within a few hours, you should be able to glide without much effort and you would have already accomplished a lot.
I fell hard on my ass twice for the first hour... for the second hour... my ass was hurting too much to keep going. 🙂
BTW, learning to ice skate is even harder than roller skating because of friction alone. You have 3 year olds who can ice skate well... so get off your a$$ and get out there...
Uh.....how about a helmet guys? One of the most common ways people learning to skate fall is when their feet shoot straight forward and then land on their ass and the back of their head. All helmets you'll find in a bike shop are ANSI certified, so you won't need to spend more than $30 or so on one unless you want to pony up a bit more for extra ventilation and lighter weight.
Much more important than wrists, IMO. 🙂
Thanks for the info guys but I have some other questions. Is there anything I should be looking for in a pair of blades, gear, etc?
Thanks again.
notfred - Like with anything, asking questions and doing research b4 spending any money, is a lot smarter than just going out there blind. Thanks for you opinion.
Your best source of info is likely going to be a knowledgeable shop employee. This means someone at a shop who actually does a lot of blading and not the yoyo at Wal-Mart who just happens to work in sporting goods. Fit will vary depending on your feet, you'll be looking at different types of skates depending on your ability and intentions, etc. Get out the yellow pages and see if you can find a shop dedicated to skates.....that should be your best bet.
Protective equipment is a must when starting out, at least get wrist guards and knee pads. You can also get elbow pads and a helmet but it depends on the terrain you will be skating on. Practice on flat pavement for quite awhile before taking any inclines and practice using your brake. Other than that, don't buy crappie skates and you should be fine 🙂
In-line skating is very simple to learn. Just buy the skates, strap 'em on, and go. It should take less than an hour before you're comfortable, and a couple of days before you're good at it.
Definitely buy knee and wrist pads to use initially. After a couple of times on the skates you probably won't need them, but you're going to fall a couple of times. I never wore pads, and I have the scars to prove it.
Plan to spend around $100 for a decent pair of skates. Any sporting goods store will have models that go as high as $400 - $500; save your money, those are definitely overkill. I prefer skates that have both buckles and laces as they fit me a little better, but YMMV. Try out several pairs, and pick the ones that fit you best. IIRC, they don't come in half-sizes, so look for a pair that's 1/2 to 1 size larger than your shoe size. I'd recommend lighter weight skates; they're more comfortable and you'll experience much less leg fatigue allowing a longer workout.
Wheels come in varying sizes and hardness. Larger wheels mean faster speed (mine are 72 mm, which I believe is pretty much standard, though IIRC they come as large as 80 mm). The hardness (is that a word?) you're looking for depends on the surface you'll be skating on. If you plan to skate primarily on hard, smooth surfaces, then harder wheels are better. If you'll be skating on rougher pavement, broken sidewalks, or pavement with a lot of seams or loose gravel, go for softer wheels. Softer wheels also have better traction, though I've never had my wheels slip on even wet surfaces. Most new skates come with all-purpose wheels, so you don't really need to worry too much about that when purchasing them.
Bearings range from ABEC-1 (not sure if any new skates even come with those anymore) to ABEC-7 (or higher). The higher the number, the "better" the bearings and the faster you can skate. Some people claim that the better bearings are a little more difficult for a newbie, but I never really noticed that much of a difference. Spacers (basically, the axle that the bearings spin around) can be plastic, aluminum or brass. In-line skating gurus claim that aluminum or brass are better (supposedly better for heat dissipation), but I've used all three and never noticed any difference.
Odds are, any new skates you're looking at will come with 72 mm wheels of medium hardness, ABEC-5 or -7 bearings, and plastic or aluminum spacers. Unless you become a hardcore in-line skating freak, that should easily be sufficient. All the parts are standard, so you can easily "upgrade" any time; if your parts aren't interchangeable with other brands, take the skates back (you got ripped off and bought some proprietary POS).
Skates need regular maintenance. Whenever you start to see noticeable wear on the wheels, they need to be rotated (move the first wheel on the right skate to the third position on the left skate, second wheel to the fourth position, the third wheel to the first position, etc.). All decent skates will come with a pair of allen wrenches for removing the wheels. If you're not going to take apart and re-grease the bearings (something I've never done), at least make sure to clean the dirt and grime off of them each time you rotate the wheels.
Skating is easy. Make sure the skates are laced or buckled tightly, but still comfortable. Stand up nearly straight, with your knees slightly bent. With one leg, push backward and to the side to starting moving; lift the skate up and bring it back in front of you, and do the same with the other leg. It shouldn't take very long to get the hang of it. Most people seem to have a hard time stopping, but I think it's pretty easy. My brake is on the right skate, so I balance on the left skate (knees bent, leaning slightly forward) and bring my right leg forward (keeping my foot straight) so that the front wheels come off the ground and the brake makes contact. I keep my leg stiff, and transfer most of my weight to the right leg, putting a lot of pressure on the brake. It takes a little practice, but once you learn how to do it, it's easy.
Good luck, and let me know if you've got any specific questions I can answer.
Thanks again.
Comfort.
A long wheel base will make the ride smoother and easier; personally, I always just try on several pairs, and skate around the store in them. If they won't let you, they don't deserve your patronage. 🙂
Rob
It's much easier if you have a friend that could teach you. As others have said, no amount of reading will help you keep your balance. I don't know where you're located, but in Boston every summer they have people who set up shop at the park and offer lessons for a fee.
Have gear, I recommend at least wrist guards. If you have all the gears, you'll be very safe and look like a ninja turtle, also it might hinder your movements. Use your own judgement for this one. IMPORTANT, don't make a fist when you're falling and trying to stop your fall with your hands. Have your hands open and land on your palm, which should be protected by wrist guard.
When shopping for blades, try them on and see how you like it. There are 2 types of braking systems that I know of. I recommend the ABT brakes. It was much easier for me to learn to use those rather than the normal type. There almost several rating for the bearings used, it ranges from ABEC 1 to 7? You should be happy with ABEC 3 for a while. The higher the number, the longer and faster the wheel will spin.
edit: Good luck. Reitz pretty much beat me to most of it. 🙂 Let us know when you're ready to blade without the brakes. 😎
