need some help
everett c
4
HI guys i am try to format my dimension 1100 desktop with windows xp pro. But when it copy and restart I got an Error message that says, "Stop: c0000218 {Registry File Failure } The registry cannot load the hive (file) System root /system 32/ config/ software or its log or alternate. It is corrupt, absent, or not writable.
Beginning dump of physical memory. "
I don't know if one of you could help me
Gunbuster
23
If you didn't nuke the diag partition hit f12 at boot and run the diagnostics.
AstroGuardian
842
Try deleting the boot partition and create it again during windows install process. Sounds like a corrupt boot partition
