I only have around 25 bucks to spend on a heatsink for my 939 socket 3200+. What one would be the best heatsink to make my cpu as cool as possible for around that price?
Try This The Cooler Master for 9.99
I had a socket A variant and oc'ed the living piss out of a thirnton core 2200+ from 1800 stock to 2413 on air cooling 43 max load temp @ 1.7 volts
