- Dec 22, 2004
- 13
- 0
- 0
I was sent to this forum by a friend of mine to get some help on building a new computer. To be honest, I know next to nothing about computer parts. I really dont know what any of the specs mean so when I started to build this computer I just went off of advice from friends and kind of threw together a machine.
First off here is what I want in a computer. I just want something is going to run smooth to be honest. I play some games (Half Life 2 is a big one which is why I need a better video card) but other than that I just want a nice computer that isn't going to give me much trouble. I want alot of RAM and a big HD so that I can won't have a problem in that department.
Here is what I decided to buy so far...
AMD Athlon 64 3000+, 512KB L2 Cache 64-bit Processor - Retail
[ http://www.newegg.com/app/View...=19-103-486&depa=0 ]
- $150.00
GIGABYTE "GA-K8NS Ultra-939" NVIDIA nForce3 ULTRA Chipset Motherboard For AMD Socket 939 CPU -RETAIL
[ http://www.newegg.com/app/View...=13-128-263&depa=0 ]
- $115.00
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200 - Retail
[ http://www.newegg.com/app/View...=20-145-480&depa=0 ]
- $146.56
Lite-On Black 52X32X52 CD-RW Drive, Model LTR-52327S, OEM
[ http://www.newegg.com/app/View...=27-106-197&depa=0 ]
- $20.00
Creative Labs Sound Blaster Sound Blaster Audigy 2 Value Sound Card, Model "SB0400" -OEM
[ http://www.newegg.com/app/View...=29-102-179&depa=0 ]
- $49.99
SAMSUNG 793S 17" SyncMaster CRT Monitor -RETAIL
[ http://www.newegg.com/app/view...=24-001-170&depa=0 ]
- $125.50
Seagate 120GB Barracuda 7200RPM SATA II with NCQ Hard Drive, Model ST3120827AS, OEM
[ http://www.newegg.com/app/view...=22-148-039&depa=0 ]
- $99.50
SAPPHIRE ATI RADEON 9800 Video Card, 256MB DDR, 128-Bit, DVI/TV-Out, 8X AGP, Model "100578L" -RETAIL Lite Box
[ http://www.newegg.com/app/view...=14-102-453&depa=0 ]
- $200.00
Total : $ 906.55
I included all the links to make it easier for you to get a closer look at the stuff Im planning to buy. I've heard that newegg if kind of pricy but I've bought from them before and their customer service is really good. If you can give me any other good websites to buy off of that would help too.
Some things to know.. I plan to use my old case and old power supply since I just recently bought them about a month ago and I don't need new ones. I have a budget of $1000 including shipping so if you give me any suggestions on what to change make sure they stay in my price range. Also, if you think anything I'm getting is unnecissary and there is something I could buy that is cheaper for the same quality product then please tell me.
Thank you for any help in advance.
- $150.00
- $115.00
- $146.56
- $20.00
- $49.99
- $125.50
- $99.50
- $200.00
Total : $ 906.55
