Your running an sis 5598 chipset (as the product specs indicate in the link you gave). You're looking for an igp graphics driver that can be found here: http://download.sis.com/
HP doesn't say what chip it uses or what motherboard so your down to opening the case and looking for the chip. Look for one that says "crystal" on it. The model number should be on the same chip.
