Need some help with OLD stuff
geek1543
I know this is a long shot, but here goes. I'm fixing up and old computer for a family with very little money. I have a MSI slot to pga370 adapter with a cele 566 that runs at 750 at 100 front bus. I want to install it in an old gateway they have. This board is running at 100 default bus. My problem is I cant find the jumper settings for the adapter. It is an MSI MS 6905 Master. I have 2 of these 1-ver. 1.1 the other is ver. 2.3. I was hoping some one out there has the jumper settings. Thanks
A 566 Celeron on a 100MHz fsb runs 850MHz😉
If the jumper settings on the slocket are only for fsb, just use trial and error.
66MHz willl run the stock 566, 100 will be what you want 850, and 133 simply won't boot, no harm done.
