Hey all I am in need of some help. (sorry don't have screen shots of anything since I am at work right now)
This is my first intel chip in a long while (last 3 chips I had were amd) and while overclocking these chips should be relativley easy I am having some issues.
I have read the intro guides to overclocking these and I also have experience overclocking my past 3 AMD chips.
I have an ASrock z68 extreme4 gen3 motherbaord with the newest bios 1.20 and the i5 2500k with the Cooler Master 212+ EVO. I first looked up what I could for guides of what others have done with this board and I tried to mimick their settings and I woudl run into issues of Windows 7 not loading, boot loops, BSOD running Prime95 or worker 1 stopping because it expected .5 and got .4 so I scrathced everything and started from scratch and tried for 4.5ghz first seeing as most people report they could achieve this. Now I left everything on auto (except I put in manual multiplier of 45 and the max current setting to 300) just to see in cpuz and real temp what voltage it would pull and the VID.
On this board auto LLC reverts to level 5 so when I got into windows I checked Cpuz and Realtemp. Under load Cpuz reported 1.35v - 1.36v and Realtemp reported VID as 1.3661-1.3771. Even set at this on auto worker 1 would eventualy stop with the expected .5 got .4 error. Temps shot up to around 85-87c under load when they were idle at about 30c. I tried numerous times to set a fixed voltage at 1.35-1.38 with an LLC of level 1 for least drop off still worker 1 would stop same error. I've tried PLL fixed at 1.75 PLL overclock on and off Turbo on, off and auto everythign I coudl think of to get 4.5 stable and I cannot.
I know many others reported they coudl get 4.5ghz stable with this board at much lower voltages even some below 1.3v. I cannot figure out why I cannot. I evne tried to drop down to 4.4 or 4.3ghz and voltages still over 1.35v and same prime95 error on worker 1. I thought maybe it was the memory I tested it came back fine. did a small FFT test in prime95 same error on worker 1.
(so sorry for thsi long post) So I am now trying to figure out what I can do! Did I just get a bumb chip? or is it the motherbaord maybe that is not helping me here or am I just missing something? Anyone have any ideas on what I can do or how I should proceed? any help would be very welcomed. Also if there is info I didn't provide please ask and I will supply it. Thank you so much!
