Need some help with my DVD player
Zipp
791
I rented a DVD last night from Blockbuster and It looked liked a burned DVD cause there was no label on it but according to the store,its a DVD in which you can use wide screen or full screen. I've never seen that before but then again I don't rent many DVD's....OK,I popped the DVD in and I get this error message saying that cannot read DVD and all the lights on the player are flashing on and off and the dam thing won't even eject the DVD.
I tried turning the player off and powering it back up but still no luck...Any suggestions on what to do?
I need to return this DVD tomorrow by noon.....I'm pretty close to taking out my hammer.:disgust:
It's a samsung DVD player by the way.
NikPreviousAcct
52,763
Many times DVDs that give you an option for full screen or widescreen will have full screen on one side and widescreen on the opposite side. This is common. As far as the DVD player, good luck.
