Need some help with HTML
Corrado
Banned
Hi,
I'm looking for someone to tell me how i can add a scroll bar to a table cell. www.phnkjnky.com is where its located at the moment, and i'd like a way to kind of treat the cells as a frame, but apparently you cant target another cell with a cell, so thats out. right now i plan on just refreshing the page every time you click a link, but i need to have a way of having more text than the cell with all the words can fit, so i'd like to make it scroll :c) if this is possible, could someone please drop me a PM or an email @ icase@matrix.gs ? Thanks
Corrado
You could try using an iframe in the cell. Then put whatever you want to display into the iframe. Then you'll get the scrollbar if needed.
-Tom
