I need to figure out how get my home network sorted out so that I can have all my devices connected and on the same network. I just need to know if I'm on the right track and if anyone has any advice that might help.
My issues are:
1. The house is wired for Ethernet, which runs to a wiring panel where the cable modem is. The cable modem (Time Warner device) only has 3 active Ethernet ports. So I was only able to connect 3 rooms to it (there are 3 more rooms I'd like to connect as well).
2. My wireless router (Netgear N900) is currently configured for DHCP, so devices that are connected to it can't see devices connected to the wired network.
I'm thinking I need to set up my router as a wireless access point for my wired home network, and I'll just need to find some info on how exactly to do that. I'm not sure what to do about getting the additional rooms connected. Can I just connect multiple rooms to a small switch and then run that to a port on the cable modem?
Some additional background info:
My wireless router resides in a different place than the cable modem. The modem is in a closet where the wiring panel is, and the wireless router is in a central upstairs location since we get better coverage with it there. I have a small NAS device connected to a switch in one of the rooms as well, and I'd like for wireless devices to be able to access it. This is probably the main driver for making these changes.
I'm also thinking of replacing the existing Time Warner modem with a Motorola SB6141 (since Costco has great return policy if anything is wrong with it), but have also been looking around for other options.
Any help would be appreciated!
My issues are:
