Need some help with Forte Agent!
Fausto
I keep getting an error message "The database file C:/program files/agent/data/000340.dat is full."
How do I fix this?
Thanks,
Fausto
What version are you using? I used to get that error a lot, but haven't since I upgraded to newer ver.
To alleviate the problem, you need to purge your newsgroups and compact the database but it will happen again when the database gets "full". It helps to set Agent to purge every time you close the program, and have it purge old articles, especially those with bodies(mine set for older than 7 days, since this is retention of the server, anyway).
