I am running WinXP and earlier I tried copying my old hardrive to a new one using Ghost. My orignial drive was partitioned as follows:
Partition A: 7gb NTFS for the OS and crucial software
Partition B: 33gb FAT32 for general storage
I'm using a ATA adapter card. I had my original drive as the master of the first IDE channel on the card and my Linux drive as its slave. I then added my new drive as the master to the second IDE channel on the card. My new harddrive is 100gb and in order to create a FAT32 parition of 80gb, I had to first use my eazy install utitlities that came with it. I partitioned the drive into two FAT32 paritions and then used winXP's setup to wipe out the first FAT32 partition and changed it to NTFS. Then I booted into Ghost and used a partition-to-partition copy for each partition on the original drive. However, when I booted into WinXP afterwards my new drive was being read as having a C: partition and a G: partition. This is a huge deal, because all my shortcuts for software point to a D: partition. Is there any way I can change the G: into a D:, or does anyone know why one of them was created as G:? Does it have soemething to do with Ghosting to it while it was on the secondary IDE channel?
