Need some help with databasing
Handsom3D3vil
61
Normally we do this all by hand it takes a few hours or more, but frankly I'm tired of doing it like this. Basically this what I have as far as variables: Link to object, Object Name, Location, Percentage. Basically it would need to look like this Object Name (Which is a hyper link) - Location - Percentage. If anyone has any info that would be any helpful thanks in advanced!
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
Get a copy of Access or MySql and play with table setups
WildHorse
5,006
(1) Take a database class at a nearby junior college. It's not just learning to work it, it's learning a way of thinking.
(2) For right now
(3) For near future.
(4) Forget MS Access. Download "MySQL 5.0 -- Generally Available (GA) release for production use " (free) & use it as the basis for working through your database class and for working through any books.
you seen to be in Windy City so these are the 2 download sites there for the WIndows Essentials package (assuming you're on Windows):
MySQL Chicago mirror 1
MySQ Chicago mirror 2
Also take note of MySQL Forge for possible templates / models / pertinent examples
You may wind up needing Crystal Reports to write the custom-designed reports off your database.
