Need some help with CS.
Stallion
I'm just about ready to go as I have all the models/maps/skins and what not loaded but when I went to join the game last night I got the message.. You don't have map/loading map from server yada,yada,yada and after the map loaded I got a crap load of text after that.
It said, you don't have ______ loaded/ loading____ now.
Don't have _____ loaded / loading ____ now. and it did that for about 30 different things then it just stopped. It said I was connected to the server but it never loaded the game.
Any one have any clues?
The map probably changed while you were downloading and the server disconnected you... download the maps from a website.. it's always faster than from the server anyway. 🙂
You can find the links in the past posts by Neo... or someone else might have them off the top of their head.. I do not. 😉
If it did that for about 30 things, it's possible that cstrike wasn't installed correctly. When you start up the game do you see a background (in the console) with a counter-terrorist holding a pistol? If not, make sure you installed cstrike to the right directory. Sometimes it's simple things like that I overlook. 😉
Yep, I get the background with the 3 guys and at the bottom in a black box it says connected to server "neomadhouse" then initiallizing and downloading and connected to server all in a black text box.
Then I get the message can't download events/aw, already exists processing events/aw
then it says can't download events/g3 , already exists processing events/g3
And it says 21 different things events/m249 ,p90 , p228 , mp5n and so on and after these 21 different files it just stops.
the black text box still says connected to server but I can sit there for 20 minutes and nothing else happens.
