Hey guys, I have a problem. I can't seem to get my E6600 past 2.8 gigs without prime or Orthos failing with this type of error:
FATAL ERROR: Rounding was 0.46875, expected less than 0.4
The Setup is as follows:
EVGA i680 Motherboard
Corsair TWIN2X2048-6400 2GB Kit DDR2-800 XMS2-6400 Xtreme (2 gigs total) (5-5-5-12 2T))
Intel Core Duo 2 E6600:
Family 6, Model F Stepping 6 Revision B2
EVGA 7900GT (not over clocked)
Seagate SATA
Zalman 9500 Cooler
I've unlinked the memory, and FSB, and left the memory at stock, and even increased it to 850, but I get the same error no matter what. When the error occurs with both Prime95 and Orthos, it seems CPU 0 is the one biting the dust. CPU 1 keeps on running.. I've tried playing with voltages for the CPU and memory (within limits) and nothing makes a freaking difference. I'm at a loss, and would appreicate any help. I'm somewhat new to overclocking, but I've been reading, and many people have been able to bump up the speed, but I'm not able to.
I'ved:
Adjusted FSB only, and let the mainboard control the voltages. Same problem, anything over 2.8gigs fails or causes reboots.
Adjusted FSB, and CPU voltage, same as above
Adjusted FSB, CPU and CPU FSB voltage, same as above
Adjusted FSB, CPU, and memory voltage (to 2.2) same problem.
Heat doesn't seem to be the issue. Things get warmer, but not past 55-58C
Here are a couple of pictures of the bios settings (I'm not using the nvidia software to make bios adjustments, just using it for reference). This is at 2850mhz, and prime95 and orthos still error out. Any ideas?
Picture 1 of the bios
Picture 2 of Bios
Bios settings #3
I forgot to mention, I had this exact same problem with the Asus P5B board.
Seagate SATA
Zalman 9500 Cooler
I'ved:
Picture 2 of Bios
Bios settings #3
