Sean Maxwell
Would I be able to set my BFG 6800 GT OC to 1.5v safely?
You would want the NV5 Silencer, the 6 is for a 6600GT. They're not bad coolers, but I prefer the Zalman VF700 heatsink. If you want a Silencer for $20 shipped, PM me I have an extra.Originally posted by: Sean Maxwell
I flashed my BIOS for 1.4v and hit 425/1.14.. thats pretty satisfying.. more would be nice though.. considering nv silencer 6.. any word on how those do?
The Zalman has performed better for me at 12V and the same as the Silencer (but quieter) at 5V.Originally posted by: Sean Maxwell
The Zalman fan performs better?.. curious because it is much smaller and different.. plus the memory coolers are smaller as well? noise is not an issue for me.. at all
I have an AGP BFG 6800GT and it does come with heatsinks for the RAM. If you're getting SLI 6800GTs, I'd seriously consider a single 7800GTX. Better performance, less heat, less noise, less power, and should be cheaper with the opportunity to upgrade to SLI down the road.Originally posted by: Sean Maxwell
what video card do you have? And does it come with memory coolers? Would it be worth to by a couple for my SLI 6800 GTs
