I need some help testing my new all in one and the fax portion of it. I had an online fax service, but I can't send a fax to it from my new machine or recieve a fax from it to my new machine.
If someone would send me a fax to see if my machine is working, that'd be great. Just reply saying you will, and i'll PM my fax number to you.
My machine rings when the fax comes in, but says ERROR. It will dial out to send a fax, but then says it can't connect.
Thanks
Thanks
