Need some help setting up dual boot
AMDPwred
3,593
I'm trying to dual boot Win2K Pro and RH7.1. I've got Partition Magic 7 and have merged my 2 old Win partitions to one 15GB partition. Now I have 5GB of unformatted space. Using disk druid, how do I setup my Linux partitions? I went in once and tried to create a 1024MB swap and the rest to /, but it gave an error and quit (something about 1024 cylinders). Then I tried the same thing with 512MB swap and the rest to /. Gave the same error. Anybody know what I'm doing wrong?
The error is saying the / partition is in error because it's more than 1024 cylinders. How can this be?
n0cmonkey
42,936
1024 cylinders is at about the 8GB mark. Try using RedHat 7.2. I think they updated lilo in that version.
AMDPwred
3,593
I got it straight and installed 7.1. Now when I boot it goes straight into RH and doesn't give a choice of Win. How can I get back into Windows?
n0cmonkey
42,936
<< I got it straight and installed 7.1. Now when I boot it goes straight into RH and doesn't give a choice of Win. How can I get back into Windows? >>
Edit /etc/lilo.conf. After adding the Windows info, run /sbin/lilo as root and reboot.
AMDPwred
3,593
After I rebooted from the install (as I was typing my last message) the system hung while booting into RH. So I can't even get into either OS. Right now, I just want to get back into Windows. I'll worry about RH later. Any ideas? Should I just boot into Partition Magic and delete the RH partitions and give the space back to the Win partition?
n0cmonkey
42,936
Boot off the Windows cd, fix the MBR with fixmbr or format /mbr. Im not sure which and it should boot Windows.
n0cmonkey
42,936
<< Let me try that quick. Thanks for your help man, this is driving me nuts;) >>
Computers suck. I hate them. ;)
AMDPwred
3,593
For some reason it won't boot from the CD. It gives a system disk error and asks for a new one. So I put in a Win95 floppy but it won't even let me switch to C or D drive.
n0cmonkey
42,936
Not sure why it wouldnt boot from cd... Never seen problems like that. Do you have a more up to date boot floppy?
AMDPwred
3,593
No I sure don't. Is there anything I can do with Partition Magic or is there some DOS commands I can use to boot into my Win partition?
AMDPwred
3,593
I could use myt Win2K boot disk and repair the currnet install. Would that do the trick?
AMDPwred
3,593
<< Try the format /mbr. I dont know if you need to be on the C: drive when you do it. >>
I have. On all the drives;)
n0cmonkey
42,936
<< I could use myt Win2K boot disk and repair the currnet install. Would that do the trick? >>
It should. Cant tell you for sure since I never left Win2k on my machines long enough to learn anything.
AMDPwred
3,593
Ok, I got it to "see" Windows again but I'm getting a BSOD. It says "Inaccessible_Boot_Device" I think I f00ked mt HHD. Do you have any idea? Oh well, guess Ilearned a valuable lesson tonight. Don't fool around with OSs.
n0cmonkey
42,936
<< Ok, I got it to "see" Windows again but I'm getting a BSOD. It says "Inaccessible_Boot_Device" I think I f00ked mt HHD. Do you have any idea? Oh well, guess Ilearned a valuable lesson tonight. Don't fool around with OSs. >>
VIA chipset? Thats the error I got when using Windows 2k with sp2 and didnt have the proper via drivers installed or something.
AMDPwred
3,593
Yeah it's the KT266A but I did install all of the drivers. What do you think I should do now? Reinstall?
n0cmonkey
42,936
<< Yeah it's the KT266A but I did install all of the drivers. What do you think I should do now? Reinstall? >>
Do a search on the forums, someone may have a fix for it. I always had to reinstall :(
