I've posted this at a few other forums with no success, so I'm going to just copy and paste:
Ok, last night my registry screwed itself up and I couldn't boot into WinXP. There is a knowledge base article on how to fix it, but it didn't work. I decided to try and use the repair option. After I ran the repair, I noticed that system files had been placed into one of my partitions on my second drive. I assumed that Windows was using that information so I decided to just reformat my windows partition on my first drive and then do a fresh install. The drive that my windows parition is on is split in two. Both are NTFS, but my Windows partition just has windows on it. After I finished installing, I looked in disk management and noticed that my Windows parition was set as a boot partition and that the other partition on that drive was set as a system partition. I don't think that is right. In the past, my windows parition was always designated as a system partition. Why is it not this time and this other partition is?
****EDIT******
Also, for some reason the drive letter of that system parition was set to F: I need it to be d:, but I can't change it because it is a system parition.
Anyone have the slightest clue as to why it is designating the non-windows partition as a system partition and how I can change it back to just a regular NTFS partition?
Ok, I figured out why it is doing it. On this hard drive I have three partitions. The first two are NTFS and the third is fat32. My first NTFS partition is for my OS. However, when I reinstalled this last time I deleted the partition first and then created a new one and then reformatted. Stupid idea I know. So upon recreating it, it treated it as the third partition. Is there any way I can reorganize the partition numbering so that my smaller NTFS parition is number 1 like it used to be instead of number 3? There is no option in the formatting portion of the WinXP setup that I could find.
****EDIT******
