need some help on my EPox motherboard!!!
PureSpeed
4
hi, everybody, i am new to this board. i just thought there are many knowledgeable people who can help me out on this one.
i bought a EPoX EP-8KHA+ mobo a year ago, it was running great until two weeks ago. that day i booted up my machine as usual, but after the bios loaded up, before load into windows 2000, a blue screen appears. it says my bios is not compliant with ACPI. so i tried to reboot and the same message appeared again. i went into bios setting and under the device manager, i made sure that ACPI is enabled and i reboot again. the same thing happend.
next day i emailed EPoX tech support, the reply was that i probably didn't install windows 2000 with ACPI enabled so i need to reinstall windows. i was like, how can that be, i've using windows 2000 for a year and it never give me message like that. but he insisted so i format my harddrive and get ready to reinstall windows. however, half way through setup, the same message appeared again. and the next time i tried, it became some memory corruption. i am just totally confused and don't know what to do? i emailed EPoX tech support yet again but they just ignored me. please help me out, any advise or suggestion would be great.
here's my machine setup:
AMD Athlon XP 1500+
Crucial PC2100 DDR 512Meg
TNT 2 ultra(don't know the brand, i salvage it from my friend's comp)
IBM 40GB HD
on board audio
thx for reading my message! :eek:
Vette73
21,503
9
I have the same problem with one of my boards.
I am about to switch the power supply out and see what that does. If that does not fix it it must be a Bad board. I am running XP Pro
But if you fix it or if anybody else has had this problem then give use a heads up.
Mem
21,476
13
Might be a clue there,I would try some different ram or test the ram you`ve installed,it`s possible it has gone faulty.Btw if you`ve two sticks of ram installed ,take one out and try installing again (with two sticks of ram installed it`s quite easy to find out if one is faulty).
If the ram is fine I would look at trying a different HD,IBM drives have not had great reliability over the last few years.
Buz2b
4,619
Unfortunately, it seems to be that some Crucial RAM is failing lately. There is another post a few down (earlier) from yours that reported the same (almost) problem and the culprit was the Crucial RAM. Start there by interchanging the sticks as was mentioned.
I am as suprised as anyone about the RAM though; I have used Crucial in countless systems with no trouble at all. I hope this is not a trend.
