need some help on mb's
bKo
for one, i'm a newbie on mother boards, so if anyoen could help me.
wat r irq's ;]
and
are dip switches is it something like jumpers?
and i've had this question ask'd b4
'sb conflicting with irq, sound evolution drivers not working'
i'm not sure if i've wrote that correctly, but that's wat i get when after it loads win98. if anyone could help me with my problems, i would thank u in advance :]
danx, late ben
my system 411:
p2@333 - w6lxb-0 - sblive5.1 - v3
also when i was thinking of getting be6-2 v2.0 w/ raid
and i was wondering. when i've installed everything. should i just put my cdrom and hd and vidcard in only? and when do i install windows.
danx again.
(as u can c, i'm a tru newbie but i'm learning 😱)
irq= basically...where your hardware sits...if yanother hardware wants to sit there...your hardware gets grumpy and all hell comes loose...but dont worry about them too much...youll hardly run into any...i said hardly
dip switches...ya pretty much same concept...without the hassle of the jumper
you should go to the properties of your sound card..dunno what OS you are using so no idea of path...check device manager...anywho...go to resources.."in 98" and uncheck use automatic settings...change irq to one that does not have conflicts...voila! should reboot...good to go!
well my os is win98plus pII@333, hope fully ur suggustion will work, can't do it now, cuz i just unistalled my soundcard =P
i also was going to upgrade to a be6-2 v2.0 with pIII@800e
if anyone can tell me more about why i shouoldn't tell me plz!!!
quesions needed help after i've installed MB:
i was wondering, when i've installed everything. should i just put my cdrom and hd and vidcard in only? and when do i install windows.
