Chapbass
Alright, so I've got all my stuff set up as far as ordering is concerned, and the final component comes down to the receiver! So I could use a bit of advice as far as comparisons.
First off, the setup:
Inputs:
My primary source is going to be my C2D HTPC thats equipped with three tuners, two analog and one HD (OTA). It also has the Xbox360 HD-DVD player that works wonderfully. It will be using an AV-710 sound card going digital out to the receiver
Secondary sources: Nintendo Wii, soon to be Playstation 3 (sooner or later at least).
Outputs:
Video is handled by a Westinghouse LVM-47 47" 1080p LCD. Also some potential for a 50" Panasonic 1080p plasma, but I'm quite sure im leaving it with the westinghouse. It looks great, no reason to change it.
As far as audio I just scored a great deal on some Klipsch reference series speakers (and no, its not a white van deal or anything like that, completely legit).
Fronts: RF-82 (x2)
Center: RC-52
Rears: RS-42 (x4)
Sub: RW-12D
For a 7.1 setup. Now, being in an apt, im probably only going to do 5.1 for now, and 7.1 in a year or two when i get a new place. So im planning on 7.1.
This system will be mainly used for Movies, and TV use. very rarely any music.
So pretty much all thats left is the Receiver. The three receivers im debating:
Harman Kardon AVR-347
Yamaha HTR-6090
Yamaha RX-V861
Honestly heres where im completely unsure of where to go. I'm leaning against the Harman Kardon, unless someone can say otherwise... but as far as the other two...im not sure.
the 861 is 100 dollars more expensive than the 6090, and is obviously a little more recent (model-wise)... But since I'll be doing a lot of stuff in HD (hddvd, bluray)...thoughts?
Id like to keep the receivers to ones that Best Buy carries, as I've got a 500 dollar gift card burning a hole in my pocket...
opinions welcome!
Inputs:
Outputs:
Fronts: RF-82 (x2)
Center: RC-52
Rears: RS-42 (x4)
Sub: RW-12D
Yamaha HTR-6090
Yamaha RX-V861
opinions welcome!
