My mom spilled soda or some such on her phone, now the keys are pressed and stuck. I'm thinking of boiling some water and see if the steam helps fix it. I need opinions before I do this.
Make sure the battery is out and use rubbing alcohol and then let it dry out. Water doesn't evaporate in an ideal fashion for use cleaning electronics.
