lozina
I've had Verizon FIOS internet for 3 years now and the speed is fantastic but ever since I got FIOS my network has always acted strangely. The problem I can most easily describe is that oftentimes I try to access a web site and it takes a while trying to load then comes up with an error page - "The connection has timed out". But then if I hit refresh (F5) the page immediately shows up. This happens a lot.
I thought my old router was the culprit so I bought a new one - a Linksys 10/100 8-port VPN Router
But the problem persists. I have multiple computers on this network and they get the same issue.
The way I am hooked up is I have an ethernet line going from my Verizon OTB (or whatever they call the box which converts the Fiber signal to video/internet/phone) directly to my router (I skipped out on Verizon's horrendous router they gave me) and then from that its wired to my PCs via cat5e cable.
Prior to getting Verizon I never had such a problem but I have no idea why this is happening.
Is there something special the verizon router does that I need to have it? Other wise everything works fine and the speeds (when I connect) are fantastic.
