Hi guys,
I'm a n00b on this forum so please bare with me. I've decided to build a new computer in the next few weeks. This is what I currently have:
AMD Athlon XP 1700+
256MB PC2100 DDR SDRAM
Abit Motherboard, cannot remember the chipset? but it was the latest VIA chipset when the 1700+ came out
Nvidia GeForce 2 GTS 32MB
40GB Maxtor UDMA/133 7200RPM
Sound Blaster Audigy
19" Viewsonic G790 monitor
Some great Altec Lansing speakers
A broken CD burner
52X CD-ROM
Generic case w/ 250-watt power supply
This PC has served it's purpose but I think it's time for something new. This will be primarily for playing games such as Doom 3, Half-Life 2, and whatever else will be coming out within the next couple of years. I am happy with the SB Audigy card, 52X CD-Rom, the monitor, and the speakers. Everything else probably needs to get replaced though.
I've been looking into the best processor for the money. I don't want to spend any more than $300 for the processor. I was thinking the Opteron 144 might be my best bet. I read Anandtech's overclocking review they did on the 144 and it looked to be blazing fast with the nForce 3 chipset. What do you guys think? I definitely want to go with an AMD product. I have heard the Opteron 144 is 333FSB but can be overclocked to 400+FSB, is this correct? Also, does the Opteron 144 and nForce 3 combo support dual channel DDR? If so, how much of a difference does this make? And lastly, how would the Opteron 144 (overclocked) compare to the Athlon 64 3200 and the Athlon XP 3200+ 400FSB?
Motherboards I haven't researched yet. I will get whichever board is the most stable and overclock friendly. And if possible, I would like to utilize dual channel DDR.
RAM, I have no idea. I haven't kept up on computer components in about 2 years, and when I checked today I discovered they are up to like PC4200! What speed would I need, and what is the benefit of going above PC3200? Would I need anything higher than that with an overclocked Opteron 144?
Video Card, I was thinking either the ATI Raedon 9700 Pro or the ATI Raedon 9800 Pro 128MB. The price difference isn't much. Is there a big difference between the two? Any other suggestions for price vs performance?
And finally, I'm debating whether or not I should go with a watercooled case. I want to overclock as much as possible and still have the system run stable. Again, need suggestions on the best price vs performace solution. How much higher would watercooling allow me to overclock everything including the video card?
Thanks in advance!!!
AMD Athlon XP 1700+
A broken CD burner
52X CD-ROM
