My friend has a house that is completely clad in aluminum coated tin on all walls and roof and his shop 25 feet behind the house is of the same construction. Because of the metal cladding a wireless network to get to the shop is not going to work. I also need to make a run from the main builing to the shop. We currently have phome wire strung between two insulators,, one on each building according to code, about 15 feet off the ground.
Is there a shielded outside compatible CAT5 cable I could string with the phone wire to make this easy? If not, what is the best way to get the CAT5 from the main building to the shop? Can I run it down the outside wall in conduit?
Any suggestions on materials and methods to make this happen are appreciated. Thanks in advance.
